Auto Column Shift Help
astark
Bronco God
The shifter on the column keeps changing position, park will relocate to where drive should be, but if moved back and forth will re align itself, then go out of alignment again, it also feels mushy and I need some advice. I checked all the linkage beyond the column and it's fine.
What do I need to replace to fix this and would a Lokar column cable system do the trick, a complete column rebuild kit, or a shift tube, or maybe something else.
Please advise and Thanks.
Gummi Bear
You talking about the indicator bezel, or is the linkage physically moving?
Have you rebuilt your column before? If not, it probably needs the collar replaced (they crack near the shifter) and new bearings, and maybe a shift tube (the key pops off the shift tube, JB weld will hold it for a little while, but you'll still need to replace it, BTDT, or a TIG welder may be able to reattach the key)
Let me know if you need any more help.
astark
astark
Bronco God
Thanks Gummi Bear :cool:
The indicator moves but not always the linkage lever where it comes out of the column, something is broke inside the column. I replaced my old broken column with this one out of a Bronco junk yard, cost me fifty bucks, and I never rebuilt it.
DebosDave'72
Bozeman, MT
The columns are a pretty straight-forward rebuild. Take it out, and take it apart, you will be able to see what needs to be replaced. I just bought a used auto column on Ebay, and took it all apart when I got it in. If you need a picture of something, let me know (the column is still sitting in the box)... The biggest job is pulling the steering wheel. I have not dealt with the shift tube or key though, so Gummi will be able to help with that.
Dave
Gummi Bear
A Stark - yours is a 76, isn't it?
If so, you'll need this kit (it has everything, including a shift tube):
http://broncograveyard.com/bronco/i-17011_column_rebuild_kit_man__76-77.htm
It has everything except the shift indicator and bezel. Be CAREFUL when you put the new bushing on the shift lever, it tears pretty easy (I had to order another one in)
Oh yeah, if you need some help, I have an incomplete tech article that I started about 3 ago, and never finished (camera died, lost the pictures and I never tore it back down for new pictures)
