the 7 circuit auxiliary fuse blocks from painless look decent.
see <
http://www.painlesswiring.com/fuseblock.htm> part #'s70107,70207,70117,70217.
each provides a different combination of always hot + switched circuits. I think they
each come with a 10ga. power feed to connect to battery, crimp on connectors, mounting
hardware, inline circuit breaker, relays for the switched circuits, and they're weatherized to
provide some flexibility in mounting in cab or more exposed (under hood, etc.). I think
each of the individual circuits is fused for 20amps and has ~16/18ga feed wire. cost
~$40-50.
there's also the bear bones fuse block such as painless part#30002. they're ~$5-10
and pretty much all the electronic stores sell them (<
http://www.delcity.net/>, etc.).
they're a bit more primitive in that they don't provide a common feed wire for the whole
fuse block, relay/switched circuits, etc. there are some with "splash gaurd"
cover but it's probably safest to mount them interior or house them in some more weather
resistent enclosure. even more primitive/basic you can use simple bus bars and
distribution blocks to feed various circuits but you would additionally have to add your
own inline fuses.
the west marine electrical section (<
http://www.westmarine.com/electrical.html>) also
carries some interesting power distribution,fuse,and switch panels. some weatherized
enclosures, etc.
