77Mule
My 77 Bronco has the dual tank option. However I can't seem to figure out in which position the selector switch below the drivers seat needs to be in to get the fuel from each respective tank to the fuel pump.
When looking at the selector handle which tank is tward the door and which is tward the transmission tunnel? adn do you use the small pointed end or the handle end as the appropriate position?
I can't seem to get gas to the carb since I rebuilt the carb today.
The gage selector is no problem as is tis stamped on the dash.
