    Discuss it more here:
OR AX15 5 SPEED conversion
nvrstuk
PNW
Want a car trans for strictly having fun banging thru the gears on the street OR do you want a trans with not only OD for cruising down the highway with decent rpms but also a lower first gear to actually be able to go off road and start off on steep incline without riding the clutch for 10' ??
I'm voicing experience as I ran a toploader for years back in the '80s early 90's and had a TON of fun with it... however, it is not conducive to anything that has an incline. lol
I got really good at taking off in 2WD low range and shifting into high range on the fly and then continue on. But with a true HP 289 in front of it and shifting at 7K everywhere I went it was fun (but axles didn't last long).
My short answer is the same as Steve's... AX all the way.
BruiserOutdoors
BruiserOutdoors
Leaning towards the AX, thanks Steve and Brian for the input. The info about inclines is important to consider. It will be a mostly street truck but don't want to limit its use.
RODRIG3911
Tucson
I've ran both in my Bronco. AX15 all the way!! The toploader was decent, but the linkage would bind off road sometimes, where as the AX15 has a shifter that goes right into the top of the tranny. Plus on the AX15, you get a lower first gear AND a 5th gear for the highway
nvrstuk
PNW
After 5 yrs or so of fighting hard shifting (only because the entire undercarriage of my Bronco being covered in mud on our 1/2 mile long farm pasture driveway) on my toploader 4 spd linkage did I convert it to a toploader shifter where I used a Jeep tower cover, welded an additional tapped bolt hole on the 4 spd housing so the Heep cover would bolt on & seal tight.
Worked great! No more shift linkage with baked on mud. :)
This was the same trans I had to run the "NASCAR synchros" in. They were a limited run for NASCAR Ford 4 spd issues back in the day.
