buckenbronco
Is an ax15 an ax15 or does it depend on what vehicle it came out of? Dodge,jeep,ford? Just as long as it is a 4x4.
Which is better external or internal slave? And should I look for a certain year
I have had both the NV3550 and the Ax15 in the same bronco behind the same motor and everything else remained constant. The NV3550 is just slightly more car like (sporty) than the Ax15. There are things like short throw shifters that i never tried, i just used the factory shifters. Both of the trans I have started out new so no issue of wear on either one. Both of these medium duty transmissions are far more "sporty" than any of the heavy duty trans mentioned. I have had all of them except the ZF.
All of the heavy duty transmissions require shifter bending and some form of modification to the major body cross brace/support up to completely removing the center portion because the shifter tower comes up so far forward under the dash.
The AX and nv3550 requires no modification to the body brace and the shifter comes out in the perfect place. Looks like it should have been there from the factory.
I am running the AX15 in my current build. Has turned out to be my personal favorite.
When you say no mods and the nv3550 will fit....my bronco is bone stoock, no body lift or nothing....the nv3550 will fit?
I don't believe there is anything that would be in the way of the PTO coming off the side of the D20. I'm doing a frame off and have my frame ready to drop on the motor and trans next week. I will look closely when i get it bolted in and confirm.
Last question. I promise.
I can use my Stock clutch linkage and bell housing with this. I'm not concerned about the external or internal slave or the hydraulic clutch configuration of these correct?
