partsloco
- Jun 15, 2004
- 405
I'm selling my Bronco C4 originally out of a 1973. I had this in my 1966 for about 5 years. Transmission has about 10K-12K miles in it. As you can tell from the pictures its very clean. This was rebuilt using a B&M race pak rebuild kit. This in the kit with the Alto Red Frictions. I have the valve body pretty much stock but it comes with all the springs and manual to modify if you want. I originally had the shift kit in it but It shifted too hard so I went back to stock. The converter is a new stock stall with about 100 miles on it. I had 3 different converters (B&M 2500 stall, TCI sizzler 2000) but truck felt the best with stock. I'm Including just about everything you need to swap out an old 3 speed stick. I like automatics better for off roading. I don't like having to worry about braking and clutching on steep angles. This transmission was working perfectly when pulled it out. I'm doing an AOD upgrade so I know longer need this. Below is what it comes with. I have close to 3K in this thing. Call or text me at 949-230-3575
. C4 transmission with B&M deep pan and new stock converter
. Cooler hard lines
. Vacuum Modulator hard line
. Cross Member
. Separator Plate
. Flexplate
. Kickdown
. Shift Rod
. Dip Stick
. Cooler hard lines
. Cross Member
. Separator Plate
. Flexplate
. Kickdown
. Shift Rod
. Dip Stick
![20160215_163301.jpg](http://www.fintechcommunications.com/bronco/C4/20160215_163301.jpg)
![20160215_163313.jpg](http://www.fintechcommunications.com/bronco/C4/20160215_163313.jpg)
![20160215_163322.jpg](http://www.fintechcommunications.com/bronco/C4/20160215_163322.jpg)
![20160215_163332.jpg](http://www.fintechcommunications.com/bronco/C4/20160215_163332.jpg)
![20160218_094809.jpg](http://www.fintechcommunications.com/bronco/C4/20160218_094809.jpg)
![20160218_094818.jpg](http://www.fintechcommunications.com/bronco/C4/20160218_094818.jpg)
