backfireing when on gas
Jeepeater
I start my bronco up, 1st shot every time. It idles for about 3 mins, then wants to stall unless I give it a little gas. After about 7mins, it idles on it own fine. Lately when I put it in drive after that, it seems to bog down and backfire. Is it loading up with gas or something? Once I get it going and step on it, it seems to clear out, then runs fine from then on. Its an 87 5.0 with unknown miles.
RajinCajun
HawleyTX, La orig.
Is this a new problem after some upgrades or just started? My 91 Stang EFI has started to hunt at idle until it warms up, it ran great for 4 months then just one day decided to start acting up..I guess it wasn't getting enough attention. I have not tried to start swapping stuff yet, but I figure I can have it plugged into a puter and come close to figuring it out. Now about the backfire, I did have backfire under gas when I first put mine in, come to find out I crossed two plug wires in my haste to get it started.
If it is something that has just started, I would say check your plug wires close and your cap/ rotor for cracks etc... Hope this helps some..
J
Jeepeater
It does surge when 1st started. surges to the point of stalling after about 3-5 minutes. After I get on the gas a littler, it goes away. Last time I used throttle body cleaner, seemed to help. Not sure whats causeing the backfireing though. I probably need to run it more. only drive it about once every 2 weeks.
wildbill
Old Bronco Guy
:cool: :cool: :cool: First thing to look at is timming and also the carb. Not nowing the motor it could have sliped timming good luck. :p :p :p Bill :cool: %) :p
edge4
Gonzales, Texas
You said 87' 5.0, so I assume it's EFI, correct? If so It could be:
1) Salt & Pepper shakers dirty or loose
2) TPS
3) IAB
4) Air leak
SaddleUp
Vancouver, WA
Since you said it is an 87 5.0 my assumption is that it is EFI. If not then that changes the diagnosis. As mentioned above timing is a possible culprit. The backfiring is fuel that is burning at the wrong time. Timing is one of the many causes of this in addition to several others like poor fuel supply. (I.E. Plugged filters or a tank that is empty) Another cause is bad vacuum. On both a carb and efi this could mean a leaking vacuum line. On EFI it could also mean a bad IAB solenoid or a bad TPS. If it's EFI check your codes and see if they turn anything up. Don't rule out sensors though if they don't code. For instance a bad TPS or IAB will not code until they go out of the limits. (I've had both go bad where they didn't actually code until they completely failed)
J
Jeepeater
I will check my timeing. How do i pull codes? I think there is a previous thread on this I remember seeing a while back.
