backup lamp switch
jason
harned, ky
my backup lights have not worked since i've had my eb. i just now got interested in fixing the problem. is the backup lamp switch on the side of my c4 near the kickdown linkage? i have 4 wires there that are stubbed out about 4" in length. the wire colors are as follows:w-r, r, r-bk, and bk-r. i looked in my haines repair manual and all i see is bk-r at the backup lamp switch.
thanks,
jason
Waverous
Aurora, CO
If I am reading your post correctly, somone has cut the wires to your neutral safety switch. For what ever reason, they bypassed the switch. It plugs into a harness off the firewall. I purchased a new ignition n eutral safety switch from NAPA part number NS6596
jason
jason
harned, ky
so thats the neutral saftey switch on the side of my tranny? i know it's not working too,because i've started my eb in gear before. so i guess i'll be wiring up the saftey switch and the backup lamp switch as soon as i get it all figured out. :(
75MIKE
NE Washington
Take a look on the top of your motor to the back and see if there is a 4 hole square wiring connector plugged into your harness. Just may be a question of sleeving the wires out.
broncnaz
If you dont put on a new safety switch you can always wire a switch in on the red/blk wires to have manual back up lights
jason
jason
harned, ky
[quote author=75MIKE link=board=5;threadid=20456;start=0#msg157511 date=1059236637]
[/quote]
the four wire plug/harness seems to be in tact. at the firewall however, their is a green wire that is running back with the four wires.this wire is cut and i'm not sure were it is suppose to go. there is a yellow wire with a female plug not being used that comes out of the firewall near the square 4 wire harness.
jason
jason
harned, ky
[quote author=75MIKE link=board=5;threadid=20456;start=0#msg157517 date=1059237870]
Where are the 4 wires you can see going? Are they just dangling behind the engine?
[/quote]
no, they are running back to the tail lights.
broncnaz
sounds like a hack job the PO must have been an electrical genius Id take the wires running to the tail lights out if they are not currently being used and try and use the ones that are supposed to be used
75MIKE
NE Washington
The hole coming out of the firewall just below the throttle bellcrank and right behind the dr.side valve cover I have 2 sets of wires.On my '75, the first set goes to the gauges and the distributor and the second set has a 4 wire pull apart connector. The wires drop straight down the bell housing and goes to the dr. side of the transmission , to the neutral safety/ backup light switch.
http://www.theofficenet.com/~pmmounce/busw.jpg
jason
jason
harned, ky
i just got finished removing the whole harness all the way back to the tail lights. i figured out what that green mystery wire was. there was a place about half way back on the wires that had been melted by the previous exhaust system. and the p.o. spliced into the back of the four wire harness and ran a wire all the way back to the tail light harness plug. so i did a little rewiring, and now my harness is almost good as new. but i still don't see where the neutral/backup switch is suppose to tie into my existing harness. maybe i'm missing part of the wiring harness thank's to the p.o.
75MIKE
NE Washington
Your Bronco originally came with the c-4 right?If it started out a 3 speed that might be where the problem lays.
jason
jason
harned, ky
[quote author=75MIKE link=board=5;threadid=20456;start=0#msg157540 date=1059247302]
[/quote]
yeah it came out with a c4. i guess i'll have to do some more homework. ::) ??? ???
broncnaz
check for a 4 wire plug underneath your throttle linkage bracket I think your look at the 4 wire connector near the fire wall that goes to the rear I think that unused wire Ie yellow you were talking about is for the axuillary gas tank
jason
jason
harned, ky
[quote author=broncnaz link=board=5;threadid=20456;start=0#msg157543 date=1059248480]
[/quote]
the wire harness/plug that comes out beneath the throttle linkage is a flat plug with four wires going into the plug and three wires coming out
one of the wires coming out goes to the coil. the other two wires coming out of the plug were cut off flush with the plug by some jackhole.
there are five other wires that come out with the harness. there are 2 red w/blue stripe wires that are twisted together with a wire nut. there are 2 blk w/red stripe wires that are cut. and a blue wire with a female plug.
75MIKE
NE Washington
Well, that's easy. The two wires that are twisted together are completing the circuit for your neutral safety switch, the reason you can start your rig in any gear.The other 2 are for the back up lights.I have a feeling the guy before you couldn't or didn't want to fix the switch on the tranny ,so this was the McGyver way to do it.Sounds like a handful of stak-ons ,some wire and some ambition will at least get it so you can see if the switch is good.Should also be able to jumper across the other 2 wires and your back up lights shoukld come on. Good Luck, Mike
broncnaz
thats the wires your looking for the two twisted together are for the safey switch and the other two are for the back up light section of the safety switch if you un twist the 2 wires it wont start the PO must have cut off the connector also the blue wire was for a solenoid for the carb
