Mazeing
- Nov 19, 2001
- 145
Several years ago I installed a Centech wiring harness to my '69 after a near electrical fire when the stock key switch got stuck in the start mode.
Since then I noticed that my lights would change their brightness based on the RPM of the engine, which I was led to believe that my alternator was going bad or not powerful enough. I replaced my stock alternator with a 135A alternator that I had bought several years before and never had the time to install it. A couple of years ago the stock alternator finally died about 90 miles from the nearest city in Arizona, of course %), so now was my chance to install the new one.
After installing the new one, it worked for a few months then stopped charging (again at the same place in Arizona - probably won't be going back there again ;D). It had a built-in regulator and I was able to find a kit that I could rebuild it with and tried that a couple of times with no luck. I finally decided to go back to a stock alternator. I fired it up after the install and thought everything was good, but the next weekend I went to start it and the battery was dead![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I bought a new battery and a few days after installing it, it was dead. So I obviously have a short somewhere.
I bought a Power Probe III to try to help track it down, but I'm not really sure where to start. I read in a post this morning that using a multi-meter you can pull one of the cables off the battery and connect one probe to to terminal and connect the other end to the fuse holder and figure out which circuit is bad.
I disconnected the negative cable from the battery (mostly to keep it from draining) and connected the Power Probe's black connector to the negative terminal and the red to the positive. I then went to the fuse block and pulled each fuse to see what would happen. On all but a few of the fuses one side was hot and the other was not. But, on the Heater, Backup/Inst, Alt/EMM and IGN SYS fuses, both sides were hot.
I'm not sure if those circuits should be hot on both sides or not or if one of them is my problem.
Any advice on how to track down my short and if anyone has experience with the Power Probe in tracking down a short, I would appreciate any advice. It's been over a year since I've been able to drive my Bronco and this is the perfect weekend to get it out and drive![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks!
Thanks!
