BC Broncos header gasket EFI swap - alternate gasket?
Postalpal
Thornton
I bought new headers for my EFI swap, upon starting I have a serious header gasket leak (yes they are tight , very tight) even tightened after a Initial start up Pulled the header back to lift out the gasket and I’d like to know if anyone has had a similar issue ? Or used a better gasket ? I can kinda see where one port is slightly burnt & was maybe leaking out of there
Thank you
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
BCB headers have been known to not fit on some aftermarket heads.
Postalpal
Postalpal
Thornton
Thaxs
These are original 96 explorer GT40 heads Just wondering if I should go with a different gasket ?
ba123
CA
I tried a bunch after having some issues with header gaskets and Remflex worked perfectly!
Postalpal
Postalpal
Thornton
I can’t get ahold of BC Broncos last couple days to ask them advice. However I did chat with brews custom
They think the issue is because of BCs raised welds & there’s likely won’t work as they shave theirs flat
My friend Rob made a suggestion that I may try or I’ll try ramflex
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
Go with Remflex gaskets. Be very careful when installing them, as they are fairly brittle.
