Bronco717274
OK, truck has been setting for 5 years. After having my 71 and all my spare part's stolen and moping about it long enough I'm going to try and get my 72 runing again. Today I pulled the fuel tank cleaned and replaced lines and filters. Removed top of carb and cleaned out filled bowl with fresh fuel. Put 5 gallons in tank. Had charger on battery while I was doing all this. Well it fired right up but had a bad miss so I started pulling plug wires and it was only running on 4 cylinders 2 on each side. I removed the valve covers and found 4 bent pushrods one on each cylinder that was missing. Motor ran fine when parked did I just have some stuck valves from setting or is something else wrong. I ordered 16 new ones from my napa guy a friend of mine I called at home today he said they would be there in the morning. What do I need to do before I install these and crank it again? And what else do I need to check for before I hurt something else.
