I buy autolite plugs on sale, gap them carefully, clean them around 12-15000 mi., and change them at around 20,000 or so. My take is I would rather put two sets of .69 cent plugs in over 40-50,000 miles than buy the $3 platinum or high end plugs. Any of the name brand -Champion, Motorcraft, Autolite, AC, etc.- are good replacements. <br> A Resistor core, 8 mm wire set will set you back $15-45 bucks depending on brand. Again, unless you run a competition mud drag Bronco with a high RPM engine, frequent inspections and normal replacement are more important than brand. I have used Taylor universal sets with good success- I like the longer universal sets so I can run them low around the valve cover and not over it. Inspect them for burns, arcs, and breaks often, never pull them off the plug by the wire, and replace at 40-50,000 miles, to be safe.<br>I have had good luck with Carter fuel pumps, but recently have bought pumps with the lifetime warranty from the Chief/Trak/Kragen/Shucks brainless-clerk parts places so I never have to buy one again. I put the old but still working fuel pump in the trail box (along with a couple of the longer plug wires and old spark plugs-you never know when you may need them on the trail or away from home) then if it fails I have one to slap on for the trip to the parts shack for my free replacement fuel pump.<br>Hope this helps- If you are looking for name brands, all of the premium brands are pretty good- but $.<br>
