- Sep 7, 2006
- 2,974
76 Bronco specs:
pwr steering
disc brakes
twin stick t-case
Detroit Tru-Trac in rear
open front
2.5" WH lift
TRO and riser for tracbar
I'v been wanting to try these new BFG AT KO2's in the snow, havn't had the chance until this past wkend, we got some snow here so we headed up the Tellico, which is about 35 mins from my house, to find a little more. I'm gonna need new tires for my 76 soon but was undecided what to get. I put a set of new BFG AT KO2's on my 74 Ranger, I really like how they ride and handle on my 74 but didn't know how well they would perform in the snow because my 74 will never see salty roads . I swapped the new AT's on my 76 to see how they would do. I can say the new AT's are a much better tire all around than the old version, I never did like the old style in the snow. These new AT's really impressed me, the type of snow we get down here is wet and ends up being mostly ice after its driven on, so traction is not the best, but these new AT's really gripped well even on packed snow/ice, and in actual snow its really amazing how good they do. I never even aired down, 28 psi front and 26 rear, this gave me a good tread pattern even with the stiff sidewall. I have to say there were only 2 place I even engaged the front diff both were on steep hills that I stopped on, and I could have gone on up in 2 wheel had I got in fresh snow.
The ride is much better and quieter, also these are a 235x85x16 E-rated. I like these tires with a susp lift, it really takes out a lot of body roll and handles better. 2 things help with this, 1: its E-rated and 2: its a 16" wheel which has less sidewall to flex compared to the 15's I normally run, as for being rough/stiff over bumps, I couldn't tell any diff in the ride between these E-rated and the 33x10.50x15 that I usually run, the susp seems to soak it up. I know these are not the same size but its all I have to compare the 2, it would been a little better had I had a set of 265x75x16 E's which would be closer the width of the 10.50, as for the height, there is very little diff between the 33x10.50x15, 235x85x16, and the 265x75x16, I know the spec charts show the 33 about 1" taller but when placed side by side mounted on 15x7 and 16x7 wheels there is very little diff. I wish I wouldv had a set of Goodyear Duratracs to test along side of the BFG's, I'v herd good things about these also, maybe soon.
pwr steering
disc brakes
twin stick t-case
open front
2.5" WH lift
