Bilstein 7100 W/Duff Hoop
JWMcCrary
I am running the 7100 with the Wildhorses hoop. I drilled a hole through the hoop and used a 1/2 bolt. I can get you a pic tomorrow if that will help.
Krawln68
Krawln68
Newark, CA
I got the hoops sitting on the garage floor now. I beleive it is just a -6 AN fitting. I may need to put an elbow on it to clear the hoop.
JWMcCrary
Here is a pic of how I did mine. Hope this helps.
ZookBronc
South Orange County
I have this setup and what i did was get a different fitting and yes it is an -6AN fitting and also drilled another hole where the shock mounts closer to the tube to give me extra clearencefrom the fender well. Did that make sense?
If i were to do it again, i would suggest doing what 73stallion recommended and that is using the F250 shock mounts.
Krawln68
Krawln68
Newark, CA
It kinda made sense. LOL. So you faced the hose toward the fenderwell, and what did you drill? What fitting did you change too? I wish i could see your shock from the other side, lol.
TJK74
Newark CA
Zook are you running the stage 1 hoops? I think there would be alot less clearance toward the inner fender on the stage II hoops that 68Steed has cause they sit up almost against the top of the fender well.
I think the F-250 mounts would work fine for a non reservoir shock like your front one but I would think that with the reservoir shock the valve fitting wouldn't clear the mount if it was to be run inward toward the fender well and if you ran it outward you would obviously have clearance issues with the tire when fully stuffed.
How do you like the ride running the dual bilsteins? What do you have them valved at?
ZookBronc
South Orange County
I am running the Duff hoop that is for non body lift and yes i faced the hose towards the fenderwell and I drilled another hole closer to the tube on top of the shock hoop. There is a bracket that the top of the shock mounts onto the hoop, i just put another hole there to move the shock farther away from the fender well.
TJK74, i had duals on the front both 7100's one with the remote resevoir and one w/o. I shock in front of the sring was limiting the travel so i took it off and now am only running one bilstein. The one w/ the resevoir and the valving is something like 360/80......its a little soft, but ist only street drivin for now so it sorks fine. If i were to do it again, id buy a differnt hoop where both the shocks are behind the spring and run no resi shocks.
raharr3
Linden,Ca
I attached my reservoirs to the hoops..these are the stage 2 with my 2in body lift
Krawln68
Krawln68
Newark, CA
With the fitting pointing toward the fenderwell, did you have to cut it, or is there enough room for it to come back around?
raharr3
Linden,Ca
I had to trim the drivers a little ..but the passengers side was fine...strange because I just figured the fender wells would be the same distance on both sides but mine were not.
