- Apr 3, 2022
- 453
Replacing floors on both sides. I have the old floors out and everything cleaned, epoxied, and ready to weld in new floors. I noticed that inside the body cross member where the body bolt goes through the floor, passes through the cross member, and into the frame, that there appears an issue.
Inside the cross member where the body bolt goes through there is a welded on ring about 5/16” tall. (See pic). However, the top of it is at least 1/4” below the level height of where the floor spot welds to the crossmember. While the floor has a slight downward indent ring where the body bolt goes through, it does not go down 1/4” to the top edge of the ring.
So it appears the body bolt will either have to bend the floor pan down to the top of the ring, or not be very tight. One option would be to add washers on top of the ring inside the crossmember to bring it up to the floor pan level.
Ring inside crossmember at firewall.
Distance ring top is from floor.
Indent depression in floor about 1/8”
![08E6E730-0B67-48E5-BD22-2593916FE1A9.jpeg 08E6E730-0B67-48E5-BD22-2593916FE1A9.jpeg](https://classicbroncos.com/forums/data/attachments/892/892734-b17aa703bcf33b7d6f41b5656114e8a3.jpg)
![1744CA79-7336-4A96-AD9C-90F77E0FA2C0.jpeg 1744CA79-7336-4A96-AD9C-90F77E0FA2C0.jpeg](https://classicbroncos.com/forums/data/attachments/892/892737-e1a746151da35e696607ef36201c5f27.jpg)
![7645A7C1-4193-4BAE-943A-0AD9333B401D.jpeg 7645A7C1-4193-4BAE-943A-0AD9333B401D.jpeg](https://classicbroncos.com/forums/data/attachments/892/892735-d30adaa33c5354ca5c1eb849a4ecdf27.jpg)
