Issaquah Bronco
I have a 1972 sport with 2.5" lift,302 with original 3 speed, that shakes like a banshee when letting out the clutch into first gear or reverse. I've read everything on the forum but haven't seen any answers that fit my scenario. Here's what has been replaced and I'm sure I"ll forget a few things... New: Luc Clutch, flywheel, TO and Pilot bearing, clutch linkage bushings, driveline, rear leaf springs and bushings, u-bolts, u-joints, engine mounts and nothing has improved!!!! If I put it in low range the problem goes away completely???? Any new ideas would be appreciated. Running 33" tires with a 3.50 differential. Once the clutch is out all is perfect and likewise if you let the clutch out with no throttle all is good
