What if you ride the clutch when you start off? over rev the engine and pull through, does this lessen the violent tremors?
I had exactly this same problem. MY clutch was shot anyways so decided to tear into it.
Since I did more then 1 thing I cannot say for certain what solved it, but here is what I did;
Installed new clutch with pilot bearing, throw out bearing, etc...
Re-surface pplate
re-built TC (I do not believe this has anything to do with it)
New mounts and bushings for adpater between TC and transmission
Now it's smooth as butter, with that new clutch smell or rather feel.
No shakes at all, I can slowly release the clutch pedal with no gas and not even a slight shimmy, whereas before it felt like a 9.2 earthquake.
A few years back I had already replaced all the suspension components and driveshafts so I knew that wasn't the cause of the 'shakes'. I did thoroughly clean the mounting areas between the engine, transmission bellhousing, adapaters, and TC as some people swear that any variance in them matching up will cause problems.
Good luck.
