I am currently sand blasting my tub. I have a few questions I am looking for answers to. This is a complete frame off so I want to do it right the first time.
1. What is a good way to remove old undercoating. Is there any chemical that will remove it, or should I use a torch and scraper.
2. I will need to change some panels after it is blasted (floorpans, kick panels, rockers). Should I prime the tub right after I blast it, or should I wait until I am dome with the panel replacement. What should I coat the new panel seams with as I am installing them? Also what should a person use for seam sealer on the seams in the tub?
3. I am planning on painting the underside of tub and inside with POR-15 and a topcoat. I don't think that primer type will effect this will it if I do immediately prime it. Is this right?
Sorry about all the questions, just have a lot of them as I get into this project.
