Boxwood Green not sure? Updated: I am sure
fordguy
So I bought a sample spray can but not sure it is what I want. see pics attached, that is the color I want. Plan on using Resoration shop I guess. The last one looks like the sample I got, too grayish for me. Y’all get me straight on the real boxwood.
Torkman66
BG can be light or dark based on year. Old trucks seem to be darker while Broncos seem to be lighter. I started with the paint code above then did some test sheets. Had it made a bit lighter.
F
fordguy
Thanks that helps. Which number is the code, top or bottom?
F
fordguy
Thanks, decision made, going boxwood. That was ginger interior you put in that build, right? What do they need at the paint store to mix this paint?
F
fordguy
Picked up a sample today
Torkman66
That looks perfect! If doing base cost clear cost, you’ll need a gallon of sprayable base unless you need to repaint and areas because of burn through while buffing. Gallon of clear will work depending on your process. Good luck.
bronkenn
Bronco Guy
Southeast Ohio
I got my paint from Chad's Paint in Michigan. It is AutoArt paint and was really reasonably priced compared to PPG. I sourced the clear from SPI online. Both were very good products with great customer support.
F
fordguy
Thanks Gus, I am going single stage. Torqman was that gallon just for body panels? I am painting everything, inside and out. SPI makes good products and has a great forum For paint and auto body.
dhendriksen
Single stage? You’re brave! I might consider clear just for the ability to fix scratches and things down the line much easier.
Torkman66
Yes, gallon of base for exterior. Single stage is hard to spray and get flat. I’ve sprayed lots of both base and SS. Depends on what you are wanting when finished.
EPB72
Pleasant Hill, CA
I also used Chad's automotive arts ,motocryl [single stage] but in compitition orange.. as well as used SP{ euro clear without any issues then cut and buffed the clear .. some people would ask why? but i like the results .....about 2 gal for inside and out engine compartment complete color change..
