bracket mystery.....
brianstrange
Just took this off the 77 frame, right next to the prop valve. Is this the bracket that holds the flexible master cylinder hoses between the mc & prop valve? Do I need this if I'm using the hard stainless lines from JBG?
Adarcy
I just installed the hard lines and did not reuse that bracket.
Madgyver
Bronco Madman
That was used to hold the stock brake lines in place. You don't need it with hard lines depending on how you route it.
