fordwheeler
I am assuming this has been an issue with some before but my brake and clutch pedal are difficult to deal with as they sit so high up. The clutch is not bad because i can keep my left foot on it, but i do hit the door handle every once in a while that can jar the door loose. The brake is the most difficult coming when i switch from the gas as i have to lift my foot up and bend my knee to the side to get in there.....
has anyone replaced these with a different set? i took it to someone to cut and re-weld, but the geometry would not be right he said.
FYI it is a 66 half cab. i know this is an issue with the older ford trucks as well. Luckily i am not real tall so i can deal with it temporarily, but I'm worried about a situation where i have to hit the brakes in a quick way....it could get bad
