Cooter_76
- May 18, 2004
- 863
I'm having some trouble with the stopping power of my chevy disc conversion.
Some background: I'm using the '76 F250 master cylinder for a dual-piston caliper truck. I also have manual brakes, and I am not using a proportioning valve. I'm fairly certain I have bled the brakes completely. I may not have enough clearance between the caliper and knuckle, and plan to check that today.
The pedal has a lot of relatively easy downward travel, and the Bronco comes to a slow stop. I've searched and read many threads on similar problems.
I'm wondering if the pedal is pushing the MC piston as far as it needs to. At rest, I can pull the pedal up about 1", resulting in about 1/4" of rod travel. I've seen posts where people have talked about adjusting the length of the brake pedal rod, but there does not seem to be any way to adjust mine (it is one solid shaft.)
Does anyone have any insight? Should I try to find an adjustable rod? Am I barking up the wrong tree?
