Bronco Dash/ heater control upgrade
nwdiver72
Tacoma, WA
Hello all,
First post in several years just got a new Bronco and the project starts. I am in the process of redoing the dash and am looking for any ideas on heater controls. I really hate the pull knob controls and was wondering if anyone has done anything interesting. I found the servo heater valve on vintage airs website and think its worth concidering. Any tips or hints would be great.
P.S. just bought a Bussman 15303 fuse/ relay panel and highly reccommed it for those that want something more interesting then the standard harness.
Thanks,
James
1969 Bronco
1985 FJ 60
1982 Scrambler(yeah I know its a J##P)
Steve83
While the servo control for the heater core flow is a good idea, the rest of that system sucks (literally). It's vacuum-operated, and not done very well. The faceplate is really weak, and difficult to mount solidly. The switches aren't intuitive, and are VERY bulky. Also, it's their proprietary setup, so you can only get parts from them, which ain't cheap.
I suggest using an '87-early '88 F-series/Bronco control panel, which is cable-operated, except for the the recirculate door. But 1) you probably won't use that anyway, and 2) it's built so it can be converted to cable if you want. It's what I use in my '83. Read this caption:
Socal Tom
San Diego, CA
I've read of people that adapted vacuum controls to the EB system. Most modern cars use vacuum controlled heater systems. you do have to have a decent vacuum source and use good tubing, but they seem to work pretty well in those cars. I think they would be even better in a car that would otherwise get cables dirty.
Tom
N
nwdiver72
Tacoma, WA
Bronco Dash
Thanks for the info,
What I would really like to find is a setup that uses electricity, servos or something similar. But if that is not possible then the panel from the later Bronco would be decent to.
James
BroncoDesign
USA
Interesting topic. I've been thinking about it for years since the negative heat/defrost system has pissed me off for longer than I can remember here in PA. The servo thing sounds good until you remember how much water and electricity don't like each other. An open bronco with relays and extra wiring is trouble looking for a place to happen. In wet environments vaccuum rules. (Hot tubs). I've also thought about what adaptable systems are available that work. The 80's vintage F-series systems work well and the High output heaters in the crew cabs work well. (I have one). I like the side to side slide controls that are still cable operated keeping it simple. Thats the way I'm going on the system I'm developing for my first figerglass tubbed demo truck.
