Bronco hut headers and exhaust
Bronco1294
I’m getting ready to install bronco hut headers and exhaust. I have never done exhaust work before and I’m looking for suggestions advice or if anyone has done these before. I’m looking for things to watch out for and some instructions since I don’t have any. Example do I use sealant? Do I torq the bolts to the specific ft. Lb?
Thanks in advance. Especially if anybody wants to help! I live in Elizabeth. I’m new to broncos so thanks!
phyler
Denver area
A few of the guys over at coloradoclassicbroncos.com run that setup. Plus there are some guys close to you on the south side of Denver.
Sent from my Venue 8 7840 using Tapatalk
Wyflyer
When I bought mine for my 5.0 with GT40P heads the headers came without gaskets. The instructions with the headers instructed to seal with high heat RTV sealant without a gasket. The headers are not a port match with the GT40P heads and will not work without gaskets to close off the space.
I had to learn all this the hard way. So ignore the instructions, make sure and order gaskets along with the headers. Call them and discuss what you are doing and they'll help you figure it out.
jmangi62
Me and a buddy installed my complete exhaust from headers all the way back to the mufflers and exit w/no tips, dumps out at the rear axle underneath. IIRC we used 2.25 mandrel bent tubing from Summit, which was important cuz I wanted good flow without those ugly bends you get from non mandrel tubes. Bought the hangers and clamps and painted everything to look nice and the final thing was to drill a hole and clamp the bung for the FiTech, I couldn't be happier with how it all came out, you're system is different than mine but the same planning and engineering goes into it. It was fun, good luck. Jim;)
BroncoChicken
The dead-soft aluminum gaskets work well with those headers. I have the same setup and the only issue I had was getting the passenger side header snug with the first exhaust section.
BroncoChicken
Used an impact and it was pretty easy. Getting it tight with ratchets would be tough. Biggest challenge was getting the passenger side collector snug, which would be easier now with the 1" body lift. A second set of hands is helpful. I used Proform wedge lock header bolts (66756) and Percy's Seal 4 Good dead soft gaskets (66014) with no issues.
