Does anyone know which direction the Bronco will lean based on the radius arms not being parallel? When I check the radius arms for parallel (out of the vehicle on jack stands on level ground) the driver side radius arm is 1 inch above the floor and the the passenger radius arm tip is touching the floor. If not changed, once reinstalled, would this cause a driver side bronco lean or a passenger side bronco lean?
