Bronco Mechanic needed in Los Angeles
broncotwister
I have a '66 that I'd like to have some things done to make it a bit safer
so my wife and eventually my son can drive it. The list isn't very long but
I'm in the early stages of remodeling our home,(full second story addition).
I don't have the time to do the things I'd like to do, the wife suggested I look for some one to do the work. I would like rear discs brakes installed to work with the front power discs I installed, I would like a 23 gal and a 12 gal
steel gas tank installed, I would like a fuel injection system, and the centech wiring harness I installed is giving false readings on the gages, oil and water temp read low, the fuel gage doesn't work. So looking for a good mechanic that know BRONCOS in the south bay Los Angeles. Willing to drive a few
miles if necessary.
70_Steve
Old Guy
You might get a better response if you edited the title of the thread to something like "Bronco Mechanic Needed in South Bay LA Area".
That way, people don't have to read all the way through your post to find out where you are. And I say that because, even though I'm not that far away from you, in Phoenix, AZ, I don't know where Hawthorne is. Might also help to change that to Hawthorne, CA...
SteveL
Huge chevy guy
Hawthorne ca
Hawthorne is kinda near lax. I'm in Hawthorne if you want to swing by and look To some of the swap options.
67RT
Your truck should be stopping well with discs in front only. Unless u r seriously wheeling...
