I have many extra parts in Tampa.
Grill $60
Tie rod
Trac bars one stock and one extended 4 inches $20 each
Tie rod extended 4 inches $20
Manual steering shaft $20
original steering wheel with center horn button corroded and split in wheel but solid for a cover $10
Chrome ash tray $7
Dual steering stabilizer brackets and two trailmaster SSv stabilizers $70
3speed tranny $50
j-shift transfer case $50 no intermediate housing
cross member $20
hurst indy shifter $20 4 spd with linkages
V-8 bellhousing 302 or 351w $45
Heater core $15
Hard top rear latch $10
Hood latch system $20
Hubs drum style $30
Hood prop $7
Front drive shaft no cv joint $20
Pair of drum knuckles $ 20
Master cylinder $10
Proportional valve $10
Drum brake line brackets and lines $10
Drums $10 each
Misc drum brake parts ie springs, spreaders etc. $5
Wiper reservoir hard type $10
½ inch thick custom cut rear matt material cost $60 $25
Cb radio Cobra 146 Gtl $40
Carter electric fuel pump $30
Stock leaf springs pair $20
U-bolts set of four $15
Clutch pivot arm $30
Clutch throwout pivot arm $15
Jack bracket $10
3spd on tree linkages $20
V-8 distributor $10
Head light ring $5
1 barrel carb $10
Rear view mirror $5
Remote oil filter sending unit $10
Seat belts mixed bag pair $10
Wiper bracket $10
Motor? $5
Window crank $3
Yokes $10 each
Large lug nuts 20 for $10
Locking lug nuts set of 4 $10
Autometer oil pressure gauge $20
Amp gauge $20
Pro flow fuel regulator $10
2inch fan spacer $5
Voltage regulator $5
Grill $60
Tie rod
Chrome ash tray $7
3speed tranny $50
cross member $20
Heater core $15
Hubs drum style $30
Hood prop $7
Master cylinder $10
Drums $10 each
Jack bracket $10
V-8 distributor $10
Head light ring $5
1 barrel carb $10
Rear view mirror $5
Wiper bracket $10
Motor? $5
Window crank $3
Yokes $10 each
Amp gauge $20
2inch fan spacer $5
