cgbexec
I have various Bronco Parts left over from my frame off rebuild. The big stuff is just too much to ship. If someone is coming down to the Naples, Ft. Myers area, they can pick up.
Everything must go so I can use my garage again. I would just prefer offers. You guys have a better handle on what these parts are worth than I. I want to be fair and sell all this stuff to clear the garage and give me some money towards a cage.
1) Deal Pending! Fiberglass Half Cab with fiberglass bulkhead (not painted). The fiberglass is in good shape. The rear window is cracked. It needs painting. Photos on page 2.
2) Original 302 Engine. It is sitting on a pallate in my garage sprayed down in oil and covered in Plastic. It will need a rebuild.
3) Original 76 doors. The have some rust on the bottom edge. I think that one of vent windows is cracked. They worked great before I pulled the truck apart. (pictures below)
4) Sold!
5) Brand New Stainless Hood Prop Rod (Went with Gas filled Struts instead). (See pictures down further in the thread)
6) Original Radius Arms (Surface Rust, but in good condition).
7) Original coil and leaf springs stock height as far as I know. The rears have about a 1.5" block on them that can be removed.
8) Stock Y steering linkage. Not sure if this of value to anyone?
9) Brand New Chrome Valve Covers - Generic. (See photos further down in thread)
10) Brand New Chrome Air Cleaner -Generic. (See photos further down in thread)
11) Original Wire harness (Probably not of value, but you never know what you can use off of it. Some photos below.
11) Original Gauge Cluster - Scratched, paint chipped and faded, but worked before I pulled it out. I went with a Dakota Digital. Photos below.
12) Original Tailgate Handle & Plate (bolt, washer and cam not included - Primed and ready for paint. I went with a new Stainless one. photos below
13) License Plate Bracket - Original - Stripped and Primed. (See photos further down in thread)
14) Brand New Ford Oil Pressure Sending Unit - Installed, but switch to Dakota Digital which takes a different switch. (See photos further down in thread)
15) Sold!
16) LeCarra 9 bolt wheel to Ford Colum Adaper (Adaper only, no wheel). (Photo below!)
17) Stock NV3550 shifter (Jeep Wranger design - will fit Bronco perfectly!). Pictures below.
18) Stock Motorcraft 2150 Carb. Was running when disasembled the truck 2.5 years ago. Should be rebuilt. Photo below.
19) Stock 302 Flywheel - in great shape, should be turned before use, light surface rust. (Pictures on page 2 of this post)
20) Sold!
21) Sold!
22) Drive Shafts (Original Length) (Pictures on page 2 of this post)
23) Home made engine lifting harness. Made from angle iron, chain and grade 8 bolts. Designed to bolt to front and rear of each head (4 points) and is adjustable for balance. (Pictures on page 2 of this post)
24) Custom lifting chains with clear tubing so non marking on what ever you are lifting. (Pictures on page 2 of this post)
And dozens of other miscilanious bits and pieces.
Everything must go! I don't want to ship the big stuff, it is just too much work. I need someone who is willing to pick up.
Thanks,
Chris B.
4) Sold!
15) Sold!
20) Sold!
21) Sold!
Thanks,
Chris B.
