jjjjjgrant
full hard top, rough, roof is pretty wavy, some rust , but can be repaired. 250.00, good solid doors $500.00 pr. , complete 9" rear end 300.00, dana 30 front needing gears 100.00, 351W needing rebuild, mated to a three speed and dana 20 t case, 300.00 for engine, trans, t case. manual steering gear box 50.00, 1987 5.0 engine out of a lincoln, had 80k miles on odometer and ran very well, includes all fuel injection set up as well as all accessories on front of engine. std intake and carb can be put on it. $300.00 front and rear bronco drive shafts 50.00 each, also have a 66 rolling chassis, very solid, running 6 cyl, three speed and t case, 850.00, has a jeep wrangler body sitting on it, body is all there,including interior, but its disassembled. $800.00 for the jeep body. bronco tube rockers, replace rusty rockers with these 2"x4" x 3/16" wall rectangle tube rockers, they have 1 3/4" round tube rub rails/body protectors $350.00 for the pair. you gain about 3" body ground clearance with these rockers. extensive cutting and welding required to install these. 404-732-6550 I'm building my bronco into a tubed out trail rig/driver, and i need: hood stock or fiberglass, front flares, soft top/doors, lift kit, winch, high back seats, harnesses, extended or wristed radius arms. may do some trading.
