This is how mine generally go... I have done a lot of AAW harnesses This is over simplified....
- Make a list of all your accessories that you are having and provide for them. Once you have taped/loomed something up you don't want to re-open it. Your "accessories" and their amperage needs will determine what gauge wire you need to run. Don't run one color wire for everything...
- Make grounds, main starter cable, if PM starter then smaller gauge wire is run as well. I place those two wires in loom, and if needed, (Headers) heat shielding as well. + Batt cable to Starter relay, but it remains disconnected
- I do the rear harness first, then I don't have to go back under the Bronco again. This includes the fuel pump wiring.
- I do the main harness on the table, get it stretched out, position everything, I see what inputs are needed for the EFI and provide them, and then begin the tape up (Tessa tape) on the main section. Connections coming off the main could be taped , split loomed, or the loom wrap. I measure the dash and get a ballpark for placement of things.
- Mount the main harness to the dash
- Pull left and right engine compartment harnesses through the dash holes with the grommets. Stretch the wires along the fenders.
- If EFI, then pull the wires I need through the fire wall into the passenger compartment. All engine connectors are hooked up at this point. Could be Explorer or Mustang harness...
- Provide the input wires to the EFI from the main harness inside.
- Hook up the connections to the dash controls, Install instrument cluster and plug it into the main harness.
- Hook up everything on the passenger side, now I should have power to the main harness. (Note unfinished wires have been taped over to prevent issues, the Batt remains disconnected) Tessa tape, high temp type, with spilt loom, or other loom.
- Hook up everything on the Drivers side, Tessa tape, high temp type, with spilt loom, or other loom.
- Ensure everything is in the off position, Attach Positive cable, Test each circuit for operation, first ones should be the ones that do not require the ignition switch to be on. Main Power wire for EFI remains disconnected from the Stater relay. Then place the ignition switch to the on position and test additional circuits.
- If all good, attach main Batt feed for EFI to starter relay. Ign switch to Run, fuel pump should cycle, I may do this a few times to ensure pressure has built up. Ign switch off and check for fuel leaks throughout the vehicle. Repair as needed to ensure no leaks, then attempt to start the engine. When it starts look for oil pressure... (I usually pull the distributor/cam position sensor and run the oil pump with a drill prior to doing a start up)
Remember its one wire at a time, don't get overwhelmed, and don't be in a hurry...
