1. '73 early bronco Dana 44 front axle. 4.11 Yukon gears, Aussie locker, Chromo axle shafts from ECGS(one Nitro 300M joint, one AlloyUSA joint), Warn premium hubs, high steer arms, HD DOM steering w/ heim end links, adjustable 3 link panhard bar, disc brakes. $800
2. '78/79 F-250 high boy Dana 44 front full width axle. 8 lug, 4.56 Yukon gears, Aussie locker, Chromo axle shafts, Yukon super joints, Warn premium hubs, high steer arms w/ 1" spacers, disc brake. U-bolt eliminator plates set at CJ width. Brand new ball joints. C's have been cut and pinion rotated up 5*. Couple of the high steer studs are broken off. $1000
3. Five(5) Cahmpion Beadlocks w/ 24 bolt rings. 15x10 5x5.5 bolt pattern. Tires are 39.5x15 TSL's, grooved w/ 25-40% tread. One tire has plugs, but was a good trail spare. $1000 SOLD!!
4. Ford Sterling 10.25 Detroit locker w/ 4.56 genuine gears and 1350 yoke. $500
5. Dana 60 Detroit locker 35 spline w/ extra 30 spline inners. 4.56 and up break. Locker is brand new, never installed. It does have a little surface rust from sitting up. $500 SOLD!!
These axles are built, proven, and ready to put on your rig.
Call 337-319-6845 or 337-316-2181 if u have questions. Pics to follow.
