My heater has a new core, new hoses and a new heat valve. With the engine fully warmed up the core feels cold. I am assuming there is an air bubble in the core. What is the best way to get the air out?
I just turn on the heater and let it idle. If nothing is plugged your water pump will clear the air out. Nothing hi tech required. If you think it is plugged, back flush the core with the garden hose. Disconnect both heater hoses and run water through it "gently". Too much pressure and you will split the heater core.
teh stock (metal valve) tend to get clogged or stick
I run one out of and astro van er stothing like , but its plastic
when you changed the core did you install new seals
that was the trick for my heater
