what I did was grind the stud off flat where the mount gets bigger. Then carefully drill down the center of the hole with a 1/8 drill bit for a pilot. I then drilled out the mount the size of the bolt and also drilled that same size into the side of the mount and plug welded the bolt in place.
I did just about the same cut it off, drilled the center of the old threaded rod. I then tapped it and am using a grade 8 bolt and washer to keep shock in place.
