So I just finished this same project yesterday. I ended up going a bit of a different route but I figured I would throw in my .02 cents for future searches. (My apologies for the hijack.) I added the Edelbrock Power Package #2027 to my 302. I was having trouble hooking up the throttle and kick down linkage. I bought the #1483 Ford adapter for the throttle and kick down. I didn't like the angle of the throttle rod though and where they had the kick down mount was interfering with the throttle.
I ended up getting the Lokar cable kick down, #KD-20c4ht and the SRK-4000 bracket. I ditched the Edelbrock #1483 bracket and the throttle rod hook up was now inline with the stock location. The kick down install was pretty straight forward however the Lokar bracket calls to be mounted on one of the rear carb studs. This probably would have worked fine but I ended up using some threaded rod and made my own mounting point using a spot on the intake that ultimately was more of a straight line for kick down operation.
I have yet to run it but everything seems to cycle through very smoothly and I don't see any reason why it won't work.
Thanks for letting me hi Jack.
