addicted
Emailed my engine build plans and vehicle information to Comp Cams and they sent me back a cam recommendation. I wanted to see if you guys agree with the suggested cam.
5.8 roller .30 over
Trick Flow 170s
Performer RPM intake
650 carb
9-9.5:1 compression
Shorty headers into a single 3" exhaust
4 speed manual (Np435)
4:10 gears
35" tires
My thinking is a can give up a little low end with the 351 and NP 435. I want to be able to cruise 70 on the highway without winding out so that's my thinking on gearing/tire size. I told Comp I wanted a cam with strong mid range power that doesn't fall on its face at 5K and I don't mind a little lope at idle. Im not planning on rock crawling. Just moderate trails and maybe some mud. Mostly just a street and play truck. Heres the cam they suggested
35-421-8
1500-5000 rpms
Duration @ 50 218/224
.513 lift
What do you guys think?
5.8 roller .30 over
Trick Flow 170s
650 carb
9-9.5:1 compression
4:10 gears
35" tires
35-421-8
1500-5000 rpms
.513 lift
