Canvas Soft Top
HB73
I had the Bestop on my rig for 10 years. It was ok. Biggest flaw to me, was the high riser in the middle. Water tended to pool over the cab when it rained, and dump over the driver or passenger when the door opened. Also the zippers tend to deteriorate and come apart.
I switched to a can back about 8 years ago , and couldn't be happier. Really nice top, sturdy and well-built, I think the BC Top is pretty similar with a slight difference in the frame. Also the top on can back rolls back over the cab. Really easy to unbutton and button the top back down. I can take the whole top off in about 10 minutes, about the same to put back on. There's just some buttons, and three straps holding it on.
The fabric is Sunbrella material, and it's held up really well in the California climate. I don't see any fading and the stitching it's still tight. The only damage I've had, was when my Cargo Carrier dropped through it while we were bouncing through Baja last year. I ended up leaving the carrier with the hotel clerk in San Ignacio. I got the damage stitched up and patched at my local upholsterer for $35 and it's a perfect match.
I don't know why you wouldn't go with the BC Broncos top, it's really really close to the can back, it costs a heck of a lot less. Plus it's actually available.
Sent from my SM-N920P using Tapatalk
Nothing Special
Maybe I am missing something here. I have a Bestop which I have not seen mentioned. It is 14 years old and still going strong (that is saying something stored outside here in the heat and sun of Texas). Side and rear windows zip out and back in in minutes. Remove it and the frame folds down. I have not had my doors on or side or back windows on in years, but they are easy to store. Keep the top on and it is just a safari top. Works for me and a lot less than the 3000 I have seen quoted on this thread.
I had the Bestop on my rig for 10 years. It was ok. Biggest flaw to me, was the high riser in the middle. Water tended to pool over the cab when it rained, and dump over the driver or passenger when the door opened. Also the zippers tend to deteriorate and come apart....
I also have a Bestop. It's been on my Bronco since 2003. The Bronco was in the garage a lot for the first 4 years, and for most winters since then, but out in the (admittedly weak Minnesota) sun in the summer. Like HB73, the high main hoop is a downside to me in that I can't drive into the garage with it up. And yes, I do get water dumping down when I open the door in the rain, but you learn to dodge it.
For the most part I really like my Bestop. It's in great shape still except for a rip where I dragged it against a tree on the trail. I'd replace it with another Bestop, but they only come with dark tinted windows now too, and I won't have that. So I just put some tape over the rip. If it gets bad enough I guess my best option will be to get a new Bestop and get a canvas shop to put clear windows in it.:(
Bronco4x4
I have a Kayline and like the fast easy drop. Clear windows too. The top can go right up if you drive into bad weather. You have to drive around with the BCB frame in place and up to be able to do the same. Just not a fan one the Canback and BCB style. Looks like an International Scout.
sykanr0ng
It reminds me of an old British Land Rover, which is not a terrible thing.
Not that Scouts are bad either.
roundhouse
Why can’t someone make a top like the wranglers have had for the last 15-20 years ?
One that folds down easy and quick ?
Unlatch the windshield and the entire top folds back like a convertible car
The wrangler unlimited two door was slightly longer than a EB
Shouldn’t be hard at all to modify the frame and maybe the canvas to fit an EB
roundhouse
For the non tinted windows
It shouldn’t be difficult
As mentioned
To get a boat shop to replace the windows with clear
You could Probabaly sell the unused new tinted ones for at least half the price of having the clear ones made
roundhouse
That seems a bit pricey. I have seen a four door 57 Chevy fold a top - big, long, high. Why does a top for a Bronco, even with a roll cage, have to be such a complex problem?
It’s not complicated
All the bronco tops are just canvas over electrical conduit bent for the bows
Take a look at a 10 yr old wrangler top
It goes up and down easy with one person
bchesley
BC and Can Bak are similar in design but execution is a lot different. Square tub frame is heavier and has more options for cargo racks and such.
thiswildbronco
Is the Can-Back the square tube construction or the BCB? Do you have the Can-Back? I understand that when they made them previously(some years ago) they were considered by many to be really great!
Are there any upsides to the BC Bronco top over the Can-Back, other than price and whether Can-Back is even shipping these yet?
Thanks!
Doug.
HB73
Thanks!
Doug.
Canback has the round tube construction like in my red Bronco above, BC has the square tubing like the white. Canback rolls back over the cab if you want the sun beating down on you, I don't think BC has that option. Canback windows roll up and strap in place, BC snap out and are stored in the truck. Both can support racks. Personally, I like the Canback better, but it doesn't look like they'll make them for our Broncos anytime soon.
