uses 1 head thread by the water jacket plug and 2 bolts on the timing cover. smog pump on top and alternator below. the cast iron bracket uses its own pulley set and a special water pump snout. which is setting on the shelf nowhere you have to order it when needed. if your not running a smog pume switch to the more common bronco alternator, water pump and pully set so you can use standard parts house parts.
