Catalyst in your EB?
BoltBuster
Anyone ever tried one or Have one? They may need a high output fuel pump with a good regulator and return line if your carburetored possibly. I would have one if it would cut down on the exhaust alone.
They are installing these on all types of trucks and vans nationwide at work to save gas and improve performance.
http://www.fitchfuelcatalyst.com/products/auto/index.html
broncnaz
LOL have you tried the tornado? or dumped some Prolong in your crank case then drain out all the oil and drove across country with no oil at all? The savings you get from this stuff is lighterweight wallet. while these products may produce some positive results they usually gain nothing close to there claims. You can gain far more basically for free if you tune your engine properly.
BoltBuster
BoltBuster
This is more of a chemical reaction than hocus pocus of Ronco, Not saying it works or it dosent. Just that it's now in over 25,000 goverment vehicles of all makes and models. :eek:
broncobilly_69
Lebanon
keep us posted as to how it works in the vehicles at your work. Could be worth while or it could be a waste of money. Your work can be our guinnea pig. ;D
broncnaz
Sounds similar to the old mothball trick like I said realistically if you just tune your engine up you'll see similar gains and usually during your test period you're more likely to drive a bit differantly so you will see the gain. Most of use tune our engines more towards the power side if you tune more towards the fuel mileage side you can do the same thing they are doing drop 1-2 jet sizes and turn timing back to stock. But you may not like how your bronco responds to this yes better gas mileage but poor performance wont be long before you turn the timing back up.
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
Cheap fix for cleaner emissions: Isopropyl rubbing alcohol.
I'm still a little bit wary on this thing, seems like a lot of voodoo. I've taken a few chemistry classes and if there's nothing to add to this thing I can't understand how it works. A catalyst is added before the reaction to speed it up or aids the reaction at the time (like the platinum screens in the catalytic converter). This neither adds products, nor is integral in the reaction (ie: fuel --> CO, CO2 and H2O). I've heard I'm a pessamist, but things that claim to defy the laws of physics usually don't.
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
Would that be the SAME government who pays $12 each for pencils and $3 each for light bulbs ? ;D . You know George Bush likes to spend money :)
