Sasquatch
- Mar 2, 2004
- 235
As I'm trying to completly rewire this truck, I'm a little confused on a few things. Heres what I'm running. 93 5.0 w/ Ryans efi harness, 4G alt. tieing it to a new centec harness and theres a few wires I dont know what to do with. Heres what I'm unsure of:
- Centech coil+, assumed not used because of EFI
- Ryans instr. tell me to tie Ign run, eng.temp and Oil psi to his harness via centechs Dark blue, blue and orange wires. I dont have a dark blue ign. run, just a yellow tach. sndr. Is this Ign. run power?
- Centech yellow Alt. wire assumed not used because of 4G connections already in Ryans harness??
- Centech purple start wire. I think if I were not EFI, its power for duraspark ignition so its not used?? Appears to only go from solenoid I term to duraspark and nowhere else in harness
- Centech green Reg. S wire assumed not used because of internal regulator in 4G??
- Centechs large batt. wire runs from solenoid to ammeter to fuse panel?? Assume not connected to ammeter because of 130 amps??
- Lastly, should there be wiring on both left and right for horns? I have wiring in the centech for 2 horns?? seems strange but then again I think there are a few probs with this harness. All of the front side markers and turn signals are labeled for the wrong side. I think I may have to rearrange a few pins at the column connector for them to work correctly with the switch.
Thanks for any insight to this as I am an electrical idiot. SB
