brian72
Early Bronco Student
- Jun 18, 2001
- 4,157
Yes, I changed radiators out.. Truck sat for a couple weeks and dead battery. Went to jump the truck and no fire, put battery charger on for most of the day. Coil tested ok with spark going to distributor, but no spark at plugs. So it has something to do with distributor.. Right?
Pull the distributor cap off and the rotor is not spinning when trying to crank truck, means probably timing chain.. Right? Cause the gear on the distro shaft seems fine.
Pulled off front end of motor and timing chain is good...what now?
Brian
Brian
