Blue71 said:
Thanks for the tips guys.
J.R. or anybody else...........Could this distributor be the stock distributor or did someone do some sort of upgrade more than 14 years ago. Truck has definitely not run or been touched in 14 years or more. Just wondering if any of the Bronco 289's had the stock Dual Points? Would you use the same points as you would with a single points setup? Would you gap them different than .017 since there are two sets of points?
Let me know.
Thanks Much,
Blue71
I would guess a paycheck that it was not stock. As Mr Joe posted, they were for high perf apps in the mid-late 60s. I would think somebody with a Mustang/Falcon Fairlane would pay good money for it.....check Ebay.
I dont think they use the same points. I think the points in the duals had stronger spring tension to prevent bounce. I never tried to use the stock (single) ones in a dual. They gapped the same. Best way to tell is ask the parts guy to see if they are the same. It's been 30+ years since I had a dual point and my memory is a little fuzzy. I would not try to use the stock ones or try to use just one set. If you dont want to be bothered, sell it and stick in a standard.
The benefit to a dual point is the high performance aspect, and better output at high RPM. A stock engine really doesnt need that.
I would wonder what the engine itself is. Visible on the outside:
1) Fatter crank damper, by about 2.5x
2) Heads (without taking apart), small tab on the leading edge of the head
near where the accessory bolts go in.....there;s a number hipo heads were something like 18 to 21 or 22. If yours are in that range, get excited. Pull the valve cover and see it=f the rockers are threaded.
3) Dual point
4) the rest is internal, crank, cam, rods................
Let us know!!
