[quote author=JustinSane link=board=5;threadid=11390;start=0#83743 date=1037637540]<br>I hooked up the on arm washers on the cherokee conversion and it works fine. I didn't have any stock nozzles. I've been able to clean plugged nozzles simply by spraying them out with WD40.<br><br>If you decide to use the on arm, NAPA has the correct size hose. I simply siliconed it to the bottom of the roof and down the drip rail on the drivers side, then under the hood. Kinda cheezy, but it will work till I come up with something better. Good luck.<br><br>Brian<br>[/quote]<br><br>I have tried everything to clean my nozzles. Soaked them in Carb Cleaner, air, etc. Anyway, my idea is to drill a hole in the windshield frame, but a rubber grommet in the hole and put the little washer hoses through them with enough slack on the outside to allow movement of the wiper arms. Then I am going to T them together and run a hose from the engine compartment somehow into the windshield frame and hook them up. I don't see why it wouldn't work and I think it would be nice to have the washers right on the arms. Kinda different and very functional.
