I did this recently on my (super awesome) Autolite 4100 on the '76. There is a kit that has a bendable tube with the correct connector to hook up to the carb end. (Throw away the little rounded cup thingy that they supply with it since you cannot seal that and in our vehicle there is just too much dust in the environment to run that choke tune open to the air like that.) Run that tube down along the side of your headers with as much of the tube in contact with the header as possible. But you should feed that tube with clean air from the air horn where there is a little tube sticking out and back (waiting for you to make use of it) just above the choke tube connection. Now take a 3 foot section of 3/16 brake line and bend it in parallel with the main heat tube, except on the far end loop it back inside the heat tube. Secure it with high temp aluminum tape or something (not required). Use a short piece of vacuum hose to connect the carb end to the air hose. Now you have a closed loop fully operational choke heat tube, young Skywalker.
