raleigh_bronco
- Sep 25, 2002
- 1,448
I've begun picking up the parts needed to do my stock 3 on the tree conversion to an NP435, however I want to make sure I have everything before I start the project. I have a stock 289. Please help me compile a list of everything required for this swap including the miscellaneous stuff that always slows us down b/c we never have it around during crunch time. Hopefully Jon will take this list and add it to the Tech Section.
1. NP435. (check)
2. Adapter to D20 (check)
3. Rear main seal. (Part number? Vendor?)
4. clutch, pressure plate, throw out bearing, flywheel (can either use stock or new parts)
5. Bellhousing. (will the stock 289/302 bellhousing work?)
6. Bellhousing gasket (vendor?)
7. Clutch linkage (can use stock)
8. T-case donuts. (vendor?)
9. Template to cut out tunnel cover (Anyone have a copy of this please email me)
10. Is it necessary to buy the tunnel cover from JBG? What if I don't have any body lift- does it require a larger hole for the install?
11. Shift boot and mounting ring (JBG)
Please add your corrections/additions and deletions as you see fit. Thanks.
1. NP435. (check)
