I am probably looking into this too much but I feel like something is wonky with my cooling system. I've recently replaced all of my hoses and I can only drain and fill the system with about 2.5 gallons when a stock system should hold about 4 gallons (see five-gallon bucket img). The radiator is (probably) a stock 3 core and the engine is (probably) a 302.
Here is what I've done thus far:
1. Drained the coolant from the radiator and by removing the bottom radiator hose AND raised the backend of the Bronco.
2. Flushed the system using Prestone Radiator Flush
3. Flushed the systems using the Peak Flush Kit (hose adapter)
4. Pulled/Opened all heater knobs during flushing and draining
5. Used a pressure kit to try to remove any and all water/coolant
6. Used a no-spill funnel while flushing/filling to burb the system
It should be noted that I haven't had any overheating issues and I am probably overthinking this. So, I'm I crazy?
