evan61977
I have just gotten a 66 bronco with a 351c and love it. However, i every time i drive the thing i smell like exhaust.......bad. I know the truck is running way to ritch. Problem is that the distributor is alluminum and is stuck. I sprayed some wd-40 down it and will drive it around to se if i can break it free. Any ideas on this? Also i am a novice to working on engines. Other than breaks and stuff i am clueless. Can someone help lay out for me where and how to use a timing light? I know i can just rotate the distributor and listen to try to hear when its running a bit smoother but i would like to make sure with a timing light that it is exactly where it should be?
Thanks to anyone that can and will help me!
Evan
Evan
