- Jun 26, 2023
- 50
So the Bronco has some new issues today. What I thought is the voltage regulator (see 1st picture) has been buzzing loudly before the engine would finally turn over. Today it was worse after a pretty long drive and the Bronco wouldn’t turn off with the key and the starter was continuing to fire. I had to use the choke to kill it. Luckily it was in my shop and not on the road.
Then after sitting for about an hour I noticed a puddle of fluid under front of motor and hear a sizzling and fluid oozing from whatever (see 2nd picture) is connected to motor and distributor with a single wire. I don’t believe it to be fuel.
Can somebody help me to identify these parts and know if the 1st is affecting the 2nd?
I have disconnected the battery for the time being.
