Casey4wd
So I am trying to put together all the parts for some courtesy lights inside my Bronco. Here is what I want:
1. Door jamb switch to turn on the lights when the door is open.
2. Switch on the dash to override the door jamb switch for when the doors are taken off or I am leaving the doors open for an extended period of time. (I am thinking a simple push button on/off switch should accomplish this)
3. Manual switch to turn on the lights when the doors are closed. Maybe use the headlight switch to do this?
So... a couple questions.
1. Is there a relay that allows two different sources to turn it on?
2. Any recommendations on door jamb switches and location to mount them? I found a couple threads on that, but curious where others mounted theirs?
While this project is months away, I want to get the parts now and make sure the door jamb switches will cooperate before I have it painted.
Thanks in advance!
Thanks in advance!
