This is my first Bronco restoration and I don’t have a lot of information on them but am learning. Can you guys look at this picture and tell me if this is what the cowl looked like from the factory?
I welded a patch panel into the one hole then blew out the cowl channel before spray injecting POR15 in the whole channel area. Once it was saturated with POR15 I fabricated what I thought the metal should look like then welded it in place. I hope it looks close to what the factor did.
I have seen many Broncos with bondo all over this area. I did not know if they were hiding this rusted area or if this is what the factor did to cover the exposed holes.
I am a novice but want to do the best job I can do.
I attached a before and an after picture.
Before:
After:
Before:
![cowl1.jpg](http://www.ragersworld.com/bronco/cowl1.jpg)
After:
![cowl4.jpg](http://www.ragersworld.com/bronco/cowl4.jpg)
