This list is on the web site:
www.truckstv.com
Crazy Horse Bronco Parts List
The base truck is a ’66 half-cab Bronco, a tribute to the great Parnelli Jones who put the Bronco in the history books with his legendary victories at Baja in the 1970s.
PRODUCTS USED ON THE CRAZY HORSE PROJECT
VEHICLE: 1966 FORD, HALF CAB BRONCO
FLOOR PANS: Wild Horses - 209-943-0991
BODY PARTS: Jeffs Bronco Graveyard – 248-437-5060 Rockers, Striker panels, Doors, Tailgate, Grille, Inner fenders, Front fenders, Core support, Headlight trim, Half-cab bulkhead
SUSPENSION: James Duff Enterprises – 360-683-2160 Front: 3 ½” long travel suspension with extended radius arms and dual shocks Rear: Duff leaf springs and dual shock brackets and shocks
BODY LIFT: James Duff Enterprises 2” body lift
AXLES: Currie Enterprises – 714-528-6957 Rear: Custom Hi-pinion 9” Ford with 35 spline axles, Detroit locker, Explorer disc brake kit, 4.56 gears Front: Custom Dana 44 with True-Trac limited slip posi and 4.56 gears
FRONT BRAKES AND STEERING James Duff Enterprises - 360-683-2160 Front disc brake kit and steering knuckles, Steering box, Drag link, Tie rod and ends, Brake booster and bracket
BUMPERS, MOTOR MOUNTS, RADIATOR James Duff Enterprises
WHEELS: Mickey Thompson Challengers – 15x10 - 800-222-9092
TIRES: Parnelli Jones Dirt Grip – 35x12.50 - 800-334-5543
HOOD: Wild Horses - 209-943-0991 Hi-Country fiberglass hood with hinges and pins and brackets
INTERIOR PARTS AND HARDWARE: Tom’s Bronco Parts - 541-779-1339 Carpet, Door Panels, Door Handles, Windshield wiper kit, Windshield Glass, Door Glass, Weatherstriping
INTERIOR AND BODY TRIM AutoKrafters - 800-228-7346 Dash Pad, Strikers, Hardware and body bolts, Shelby bullet side mirrors
WIRING HARNESS: AutoKrafters – 800-228-7346 Centec wiring harness for Bronco Ignition switch and dash knobs
STEERING WHEEL, COLUMN, AND GAUGES Wild Horses – 209-943-0991 Chrome tilt column and LeCara steering wheel Digital Gauges with sending units and harness
TOP: Auto Krafters –800-228-7346 Original metal half-cab
SPARE TIRE CARRIER RJR Products -800-632-9192
ENGINE: Built by: Automotive Specialists - 704-786-0187 Crank, Rods, Pistons – Lunati 349 stroker kit Heads – Holley Avenger Carburetor – Holley truck Avenger Push rods, Lifters, Cam, Roller Rockers – Lunati Intake, Water Pump – Weiand Stealth Distributor, Coil – Mallory Unilite, Pro Master Coil Plug wires – Accell 9000 Valve Covers – Vintage Holley Headers – Wild Horses Oil pan, Windage tray, Main stud support – Canton Racing Products
TRANSMISSION: Advance Adapters – 805-238-7000 NV 3550 – 5spd, Crossmembers, Linkage Centerforce Clutch, Pressure Plate, Throwout Bearing
TRANSFER CASE: Advance Adapters – 805-238-7000 Atlas II – 3.8 ratio
SHIFTER: B&M
DRIVESHAFTS: Hi-Angle Driveline – 530-877-2875 Custom – made front and rear shafts for extreme angles
WINCH: Mile Marker – 800-886-8647 12,000 lbs electric winch
LIGHTS: Dick Cepek – 888-398-7877
ROLL BAR: Wild Horses – 209-943-0991 Custom dual rollbar for half-cab Bronco
SEATS: Wild Horses – 209-943-0991 Procar Rally seats
BELTS/ RESTAINTS Crow Enterprises – 714-879-5970 Purple 5-point harnesses with 3” wide shoulder and lap belts and 2” anti-submarine belt
GAS CAP: Moon Equipment (Mooneyes) – 800-547-5422 Polished Aluminum “Flip” cap
HEAT / AIR CONDITIONING UNIT AutoKrafters – 800-228-7346 Vintage air Heat and Air unit for Early Bronco
PAINT STRIPPING: Blast from the Past – 615-453-3002
UNDERCOATING: Line-x – 800-831-3232
PAINT: Color scheme and layout is similar style to two-tone on Parnelli Jones’ gold and white Big Oly as a tribute Applied by the Nashville Auto Diesel College Air Brushing of Horses Head, Flames, Graphics, and Lettering – Designed and painted by Johnny Watson
COLOR: House of Kolor – Designer Pearls – 800-845-2500 Passion Pearl Snow White Pearl
LIGHTS, TRIM, EMBLEMS: AutoKrafters – 800-228-7346 Toms Bronco Parts – 541-779-1339 Jeffs Bronco Graveyard – 248-437-5060
ENGINE ACCESSORIES Tuff Stuff - 800-331-6562 Chrome starter, Hi-output Alternator, P/S pump
ENGINE PULLEYS AND BRACKETS March Performance - 734-729-9070 Polished pulleys and Brackets
BATTERIES: Optima yellow-top Deep cycle
DUAL BATTERY KIT Wild Horses – 209-943-0991
BATTERY BOXES Mr. Gasket
EMERGENCY BRAKE HANDLE AND SHIFTER BOOTS Lokar – 865-966-2269
ELECTRIC FAN Spal – 800-345-0327
